    Nov 2012
    5
    Default Transmission Tunnel Construction
    Hi,
    I Was wondering if anyone can give any tips for constructing a new transmission tunnel in a race car.
    The car is FWD so the tunnel is only for the exhaust pipe. We need to remove the existing tunnel which is too small for the exhaust/oil lines etc which will run down the centre.
    We will replace it with one which is larger, and I was wondering if anyone could give some tips on tig welding the new tunnel to the existing floorpan. would one tig weld along the full length of the tunnel (from the firewall to where the floor pan kicks up for the rear seats etc) or would you stitch weld it?
    Cheers
    3,945
    I have welded in a few of them. Mig welded soild to keep the fumes out. I suppose you could stitch it and use a sealer. Why tig weld?...Bob
    We built a pro-street car a few years ago, mig welded, cleaned up the welds then 3M brush able seam sealer then paint. It looked factory and held up to body flex= no cracks.
    Nov 2012
    5
    I originally wanted to use gig as it was cleaner/neater... would using a tig be a bad idea?
    3,945
    Quote Originally Posted by Bosco26 View Post
    I originally wanted to use Tig as it was cleaner/neater... would using a tig be a bad idea?
    You can use what ever process you want. If it is steel i would use a mig and .024 wire but thats just me speaking. Post some pics when you are done...Bob
    1,895
    I think it would depend mainly if it will be structural or not wether to stitch or full weld. A uni-body uses the tunnel for support/strength. Now if the car has it's own frame or cage then it most likely isn't structural. Without pics it is hard to even give an opinion.
    Jul 2010
    Niagara on the lake Canada
    12
    Default tranny tunnel
    make it out of cardboard and duct tape. When you are happy cut out and fab with sheet.
    Nov 2012
    Northern Arizona
    538
    x2 on the cardboard mockup. I'd seal it up with fully welded seams with a mig. Whats the material?
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Nov 2012
    Northern Arizona
    538
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
