Results 1 to 8 of 8
    Default lens magnifier and jacket ?'s
    im gona get my dad a lens magnifier for his welding helmet for christmas but what diopter would you guys recomend? his eyes arent too bad. also could you guys recomend a decen welding jacket that protects from the uv rays but it still kinda light so you wont get all hot and sweaty. thanks.
    Aug 2010
    1,099
    Quote Originally Posted by slow50 View Post
    I assume he does not have one yet so I would recommend a #1 diopter. It magnifies a tad, but not too much that it would be a shock.
    As for the jacket I use a Cape sleeve with a snap on bib. The back is completely open and the bib keeps his shirt clean. Miller makes some good stuff and I would recommend the color black, as it reflects the least UV ray up under the hood.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Raymore Missouri
    1,908
    If he wears reading glasses, look for the diopter strength. We have no idea how good his eyes are.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Illinois
    460
    how old is he ? Some magnifiers did go by age .
    thanks for the input he's 55 ive seen him wear reading glasses once he said he used them for the bifocals but i think they belonged to my step mom. he's always complaining about not being able to see the weld as he's welding so i thought the magnifier would be good.
    Aug 2010
    1,099
    Perhaps you should think about buying him a visit to the optometrist. I use a #2 and on some occasions double up with a #2 reading glasses. I am 56.
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Montana, USA
    201
    Suggest you start by determining what power to put in your dad's helmut by dragging him to a store that has a variety of readers, so he can try them before purchasing the lens. This way your dad can see what power is best at his normal working distance when welding. I prefer a stronger power when tigging, compared to mig and stick. At the age of 55 years your dad, most likely, will benefit by using at least a +2.50 add. I use a +3.50 for tig. The "add" is the power of lens used in addition to the distance correction.
    Dec 2011
    231
    Default .02
    His age is not a reliable indicator of what strength of magnifier is appropriate. I'll be 60 soon and have only recently graduated to a +1.5 from a +1.25. And too strong is not better than not strong enough. You need to get him to check out the magnifier eye glass tree at the local store.
    Good Luck.-Meltedmetal
