    6,752
    Default PiipePro 350 Mitsubishi models problem
    Encountered a problem with this engine having low temp issues. It appears that the temp sender is screwed into far pushing the internal thermostat off its stand and allowing coolant to pass freely. The engine will not come up to temp and you may encounter the unit wet stacking because its running too cold. So if the coolant temp guage doesn't read anything, this is the problem. Take it in for repair ASAP!
    Nov 2008
    Troy, OH near Dayton
    43
    Default Clarification
    Cruizer,
    What is the normal operating temp for this unit in your opinion, when it's up to speed and running on high idle? In other words, besides obvious wet stacking signs at the exhaust, how do you know you have a problem?
    Mine has always been on the cold side of the temperature gage. I ran it about 4 hours yesterday, and the engine temp stabilized at about 140°-145°F; just barely registering on the gage. It was in the mid 40°F's outside at the time I was working. I've seen it run maybe 10° higher in the hotest part of the summer, but that's it.
    I always thought it was a bit cold-bloooded. But it starts and runs well. I've seen no signs of wet stacking from my machine, the exhaust residue has always been dry and no visible smoke ever during operation.
    Benson's Mobile Welding & Fabrication
    www.bensonmobilewelding.com
    Serving the Dayton, Cincinnati, and Columbus, OH metropolitan areas
    Nov 2008
    43
    Default hijack
    Cruizer,
    Pardon the hi-jack, but do you know what the cross references are for the oil and fuel filters for the BB350 Mitsubishi engine? I'm due and I'd rather buy them locally at an auto parts store than order them through my local welding supplier.
    Thanks.
    6,752
    These engines do run at 140, so if the gage is registering, then you don't have this out of position thermostat.
    6,752
    Baldwin cross reference oil filter - B1402
    Best to keep on using the Donaldson P821575 air filters, or its Luberfiner counter part
    Fuel filter in baldwin is a BF9835D
    I only use Factory, Donaldson,Baldwin or Luburfiner filters. Tried the rest, taken them apart, and found them to be pure juck, especially Fram.
    Nov 2008
    43
    Thumbs up
    Thanks for the info and for setting my mind at ease regarding normal operating temps.
