Results 21 to 30 of 37
  1. #21
    Jul 2009
    Australia
    1,031
    The triangle transfer sub-frame.
    Ji
    Grip it and Rip it
  2. #22
    Jul 2009
    Australia
    1,031
    Okay I have now taken a look at that skibike.
    Complicated hip and knee joints.
    And your feet are on the outside of the rear ski posts.
    Ji
    Grip it and Rip it
  3. #23
    Jul 2009
    Australia
    1,031
    Grip it and Rip it
  4. #24
    Nov 2012
    15
    Quote Originally Posted by Jigantor View Post
    Yeah, in my portfolio I did research on several ski bikes and that was one of them, I cant believe that the best solution was starring me in the face the entire time! I'll be wearing snowboard boots when I ride it and that sketch you did, would it still be able to edge the skis because I cant see how, it would need another horizontal beam at the top, it could be a lot smaller than the lower one though.
  5. #25
    Nov 2012
    15
    Yes I mean your weight including clothes, safety gear, back pack, water........
    Also will you be jumping this thing? if so what height and to a flat landing or to a down ramp?
    Ji
    And I forgot to answer this, I shouldn't weigh more than 70kg with all of my stuff but I'm only 15 so will still grow quite a lot, and yes I am definitely planning on going big on the jumps and I will probably ending up jumping or dropping to flat. I know that everything will eventually break but I want to eliminate the risk of it breaking on me in real world conditions, eg I want it to be built like a tank but weight is still a concern, just secondary to strength. Ideally I would like to order metal tonight, (uk time) school deadlines. Do you think 2-3mm would be ok or should I go thicker?
  6. #26
    Jul 2009
    Australia
    1,031
    Before you order anything.
    Have you worked out dimensions of each member?
    If so estimate how much this thing is going to weigh including the skis for 2mm and then 3mm.
    Next check the slopes where you intend using it to see if they will let you on their lift with it.
    Remember on a lift you will have to hold it for the length of the trip to the top.
    If they will not let you on than you will have to push/carry this thing to the top.
    Weight will be a major factor.
    Not all lift operators will let you on with a hand held bike.
    The next issue is that pivot swing arm. How ever you are going to do it work them out before ordering. These will be very difficult to get to work perfect the first time. The front of the skis when in the air will tilt down, you have to come up with an idea to make them always stay level or tilt up. Or when you land the bike will nose dive.
    Big air is not a length. You will have to work out what you think your body can absorb to a flat landing and then use it for the design. Without shocks it won't be much as your ankles/knees will collapse and your men bits will smash on the cross bar.
    Ji
    Grip it and Rip it
  7. #27
    Jul 2009
    Australia
    1,031
    50x50x3mm SHS aluminium square tube has a mass of 1.52kg/m length.
    I estimate that there is about 5.45meters of this tube having a net mass of 8.3kgs.
    The unit still needs handle bars, head stem single or duel front steering arms, rear swing arm pivot hardware, foot pegs, seat and three skis to account for weight wise.
    The unit will be at least 20 kgs.
    Are you sure you can carry/handle/hold that all day?
    And hold on to it on a lift.
    Work out what all the parts weigh and check my assumptions, then go carry something around that weighs a similar weight. An aluminium 88cf scuba tank weighs around 20kgs and it is not easy to carry more than 20 meters on flat ground.
    Ji
    Grip it and Rip it
  8. #28
    Nov 2012
    15
    over 20kg!? When I'm over estimating I cant get above 15kg! And anyway, the way I'm doing it is that you go on chairlifts the same way as on the north legion smx and tow lifts should be easy.
    What did you mean by this?: "The next issue is that pivot swing arm. How ever you are going to do it work them out before ordering. These will be very difficult to get to work perfect the first time. The front of the skis when in the air will tilt down, you have to come up with an idea to make them always stay level or tilt up. Or when you land the bike will nose dive."
    Just out of interest do you ski or mountain bike or are you just an experienced welder?
  9. #29
    Jul 2009
    Australia
    1,031
    I have been snow boarding since 2002.
    I also mountain bike as training for motocross.
    Ji
    Grip it and Rip it
  10. #30
    Nov 2012
    15
    Awesome! So what did you mean about this "The next issue is that pivot swing arm. How ever you are going to do it work them out before ordering. These will be very difficult to get to work perfect the first time. The front of the skis when in the air will tilt down, you have to come up with an idea to make them always stay level or tilt up. Or when you land the bike will nose dive.!
Tags for this Thread
