    Nov 2009
    South Alabama
    255
    Default Tig Cooler On or Off
    We just added a tigmate 3 to and old syncrowave 250 at work. I was busy with another project when it came in and someone else installed it and hooked everything up. Yesterday was the first time I have tigged anything since. Well in a hurry and getting late in the day I flipped the welder power on, started to weld and burnt a hole in the hose. Everywere I have ever welded with a tig cooler on the welder, the cooler was left on and pluged into the switched outlet on the welder. The 250 has a switched outlet on it and the cooler is pluged into it. I have checked all the manuals and cannot find anything saying you can leave the cooler power on or not to. Which way should it be done?
    "The only source of knowledge is experience." Albert Einstein
    Aug 2010
    1,106
    Yes, leave the switch on the coolmate on. That way it activates automatically when you switch on the welder. Most all other coolers don't have a switch.
    Helps to verify coolant flow every time you start up anyway. Put a piece of tape over the switch in on position.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Nov 2009
    South Alabama
    255
    I thought so, I never saw a switch on one before this. Only makes since, why else would they put a switched outlet on the welder. Thanks
    Aug 2010
    1,106
    Quote Originally Posted by Diverdude View Post
    The switch is nice if your welder does not have a 115volt outlet. Never seen a water cooled mig welder outlets.
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Nov 2009
    South Alabama
    255
    I've never seen a water cooled mig but while I was checking the books on the cooler it showed a water cooed mig setup.
    Oct 2009
    257
    I run water cooled mig at work. Coolmate 4 on switched outlet of machine.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
