Results 1 to 10 of 10
    Aug 2012
    Hermiston Oregon
    286
    Default battery. dies every couple of weeks?
    The battery on my bobcat 225nt dies. What could it be. ive checked the cables. Their tight. What's the voltage need to be while running? 14v?
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Dec 2011
    436
    Load test your battery with a carbon pile. Put an ammeter, dc clamp-on, type to verify that your battery is being charged and check with the same ammeter that the battery is not being discharged in the off condition . Proceed from there.
    Meltedmetal
    Oct 2004
    Edmonton, Alberta
    8,330
    That or your oil pressure switch is defective and keeping the circuit closed, thus draining your battery
    4,487
    I got one draining, hadnt thought of that.
    Aug 2012
    Hermiston Oregon
    286
    Newer battery. But I'll. Check it.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    Aug 2012
    Hermiston Oregon
    286
    Is there a way to trouble shoot the pressure switch. Where's it located?
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    Oct 2004
    Edmonton, Alberta
    8,330
    Under the left side engine shroud, kinda under the coil
    Oct 2007
    Cave Creek Az
    1,068
    Not having gone out and looked at mine (too cold) I would guess just disconnect the wires and use the continuity test on a multimeter and check for continuity if you do it is stuck on, if not its okay. That is just a guess, but that is the first thing I would try.
    Aug 2012
    Hermiston Oregon
    286
    Ok thanks for the idea I'll try. That. I just been busy I get to it later or tomorrow. Thsnks.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    Dec 2011
    436
    Short-cut from the voice of experience. I'm guessing that this is a common failure (Judging from the line-up with similar complaints.) and the suggestion is to swap it out. It's about 35$ for the kit at miller4less. If you really want to be sure that was it, check before and after for current drain when in the off position. Meltedmetal
