The battery on my bobcat 225nt dies. What could it be. ive checked the cables. Their tight. What's the voltage need to be while running? 14v?
Results 1 to 10 of 10
11-21-2012, 04:01 PM #1
battery. dies every couple of weeks?
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#
11-21-2012, 05:47 PM #2
- Dec 2011
- 231
Load test your battery with a carbon pile. Put an ammeter, dc clamp-on, type to verify that your battery is being charged and check with the same ammeter that the battery is not being discharged in the off condition . Proceed from there.
MeltedmetalLast edited by Meltedmetal; 11-21-2012 at 05:50 PM. Reason: dyslexia
11-21-2012, 06:00 PM #3
That or your oil pressure switch is defective and keeping the circuit closed, thus draining your battery
11-21-2012, 07:20 PM #4
- Sep 2005
- 4,247
I got one draining, hadnt thought of that.
11-21-2012, 09:06 PM #5
Newer battery. But I'll. Check it.
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
11-21-2012, 09:08 PM #6
Is there a way to trouble shoot the pressure switch. Where's it located?
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
11-21-2012, 09:23 PM #7
Under the left side engine shroud, kinda under the coil
11-22-2012, 07:37 AM #8
- Oct 2007
- Cave Creek Az
- 797
Not having gone out and looked at mine (too cold) I would guess just disconnect the wires and use the continuity test on a multimeter and check for continuity if you do it is stuck on, if not its okay. That is just a guess, but that is the first thing I would try.
11-22-2012, 12:18 PM #9
Ok thanks for the idea I'll try. That. I just been busy I get to it later or tomorrow. Thsnks.
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
11-22-2012, 04:59 PM #10
- Dec 2011
- 231
Short-cut from the voice of experience. I'm guessing that this is a common failure (Judging from the line-up with similar complaints.) and the suggestion is to swap it out. It's about 35$ for the kit at miller4less. If you really want to be sure that was it, check before and after for current drain when in the off position. Meltedmetal
