Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Apr 2011
    11
    Tap Magic is not made to be diluted. Get some water soluble oil and go with that, been using it for 35 years now and that's the best way to go. When you mix it up it will look like milk, hence the nickname we gave it many years go, monkey milk!
    Aug 2010
    Chesapeake, Va
    96
    I get my cutting lube from fastenal I think it is around $60 for a 5 gallon pale.
    Miller pro 300 perkins diesel, 30 amp spool gun , Hobart 210 with spool gun, Thermal dynamic pak master 75 all mobile all ready to go.
    Sep 2012
    London
    20
    Quote Originally Posted by jaden View Post
    Hi, i am wondering if i can use "cutting oil" as a coolant for my bandsaw.
    the product that i have is "tap magic pro tap" i ended up with this product because it was the only thing that i could find in less then a 20 litre pail.
    my question is: is this product able to mix with water and if so at what ratio? and will it run through my coolant system on my saw?
    the saw is a king canada 7" x 12"
    thanks in advance.
    I think you should contact to any professional ,that would help you a lot
