Results 1 to 3 of 3
    Dec 2005
    BC Canada
    14
    Default Trailblaser 302 running a dynasty 300
    Does anyone do this on a regular basis?
    I have no option to plug into power, due to the fact project is at least 9kms from the closest power line...
    Will a newer 302 run a dynasty 300dx tig on AC 250amp/????
    MM 130 110v Mig
    Spectrum Cutmate 300 110v/240v Plasma
    Syncrowave 250 Tig, oldie but welds nice
    Dynasty 300 DX Tig, very nice machine, AC doesn't start most of the time
    Los Angeles
    2,933
    Looks like the 300dx is rated at 61amps Input for 250amps welding output.
    TB302 only has 11,000watts of continuous power
    11,000/240v = 45amps.
    http://www.millerwelds.com/om/o358ag_mil.pdf
    http://www.millerwelds.com/pdf/spec_sheets/ED4-78.pdf
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Oct 2004
    Edmonton, Alberta
    8,231
    It's pretty dirty power to run such a expensive machine on, though I suppose it would work, The internal inverter system should handle it. Why do you need to run it in the field anyways. Not difficult to tig off your TB even in AC with a hf box.
