What ya do is take the machine only into another service depot, and act like a dumb maid, ie, "I don't know what happened, it was working one day, but didn't work the next." Or be one of there very few, and tell em what actually happened.
Results 11 to 17 of 17
11-14-2012, 12:12 PM #11
11-14-2012, 12:20 PM #12
Yeah, be sure to show them the cable too
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
11-15-2012, 12:35 AM #13
- Jan 2007
- Montana, USA
- 200
0. It sounds like wires to the variable resistor, controlling amperage, have been compromised.
1. What part of the cable was broken?
2. Was the cable plug going into the machine distressed by the steel falling on the cable?
3. Were wires in the cable cut (or shorted) by the steel? Which colors of wire strands in the cable were cut/shorted by the steel?
4. If you can check the voltages at the pinouts for the pedal (found on the schematic), it might give you a clue to where the defect exists.Last edited by Goodhand; 11-15-2012 at 01:04 AM.
11-22-2012, 01:18 PM #14
- Nov 2012
- 18
well. I ended up sending the unit in to the place that i bought the welder and they sent it in for repair
I told the guy what happened and sent in the foot cable. ends up that it fried the circuit board in the welder! wow. I was surprised that they dont install some sort of safety device for this.
anyways they are going to replace the circuit board under warranty so i guess thats all that really matters.
good to know that miller stands behind there products in a scenario like this
11-22-2012, 02:08 PM #15
Glad I bought miller
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#
11-23-2012, 09:37 AM #16
- Oct 2006
- 642
What you are saying is that when the foot pedal is plugged in it overrides the controller on the torch.
Assuming that the controller component in the torch, maybe a variable resistor, is the same as that in the foot pedal then it would appear as though when the metal piece cut through the cable it shorted out the wires and fried something common to both the foot control and torch control.
That is most like a controller circuit board but is troubleshooting that within your capabilities.
Keep in mind I am taking a guess at this because I do not know that specific machine, but I am an electronics technician.
11-23-2012, 11:15 AM #17
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
