Hi, My first post here. I have an Airco with a Kohler motor. It all worked last time I used it but when I fired up the motor recently I got no output. I plugged in a trouble light which lit and then died much like a capacitor discharging. Now it won't do that and I read 10V AC at the generator outlet. The only number I can find on the welder is W537125 and I saw somewhere it might be a style W1. I checked the brushes and cleaned the tarnish off the slip ring so far.
I have attached a couple of pics to help ID it. I would appreciate suggestions of what to check or help getting a manual for it.
Thanks, Joseph
Results 1 to 5 of 5
Thread: another old Airco needs ID
10-02-2012, 07:29 AM #1
- Oct 2012
- 3
10-02-2012, 09:09 AM #2
- Jul 2010
- Four Flags city
- 236
Looks like my Roughneck.
http://www.millerwelds.com/om/o419f_mil.pdf
From Millers cross reference list
Airco Miller
1.8ADG-AMEL-A ROUGHNECK
1.8ADG-AMPL-A ROUGHNECKLast edited by big mike; 10-02-2012 at 09:17 AM.
10-02-2012, 11:33 AM #3
- Oct 2012
- 3
[QUOTE=big mike;294061]Looks like my Roughneck.
Sure does look like it. On mine the throttle arrangement doesn't have the labels for Power & Weld and some of the internal electronics look different. I think I might have an older model than the manual shows. Thanks, I'll do some more investigation on the roughneck line but the manual you have helps a lot.
Joseph
10-08-2012, 10:55 PM #4
- Sep 2012
- London
- 20
Hi Joseph, hopefully this link can help you out with the manual instructions http://www.millerwelds.com/om/o340d_mil.pdf. It contains a detailed description of every component and the problem with their causes that can disrupt their normal functioning.
11-12-2012, 09:30 PM #5
- Oct 2012
- 3
