Results 1 to 3 of 3
Thread: settings
    Nov 2012
    2
    Default settings
    Hi, I need some help. I have a Millermatic 130xp and I want to practice some welds on some 1/4" steel plating. I need to know the regulator, wire speed, and amp settings I should start off with. I can adjust the other settings accordingly as I go but I need to also know if the gas regulator setting always remains the same no matter what you are welding. Thanks
    Jun 2012
    Tracy, CA
    221
    Here's the manual for the 130XP.
    http://www.millerwelds.com/om/o1316f_mil.pdf
    Lincoln Vantage 400
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    Multimatic™ 200
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Victor Oxy/Acetylene Set
    Salem ,Ohio
    3,964
    Cool
    I think you should drop down to 1/8" or under to practice on. 1/4" will be pretty tough for that little welder...Bob
Tags for this Thread
