Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
  1. #21
  2. #22
    Apr 2011
    306
    I'm not sure what has you so fired up but I will address your concerns:
    I agree-that a lot of receptacles are wired incorrectly but in THIS case the receptacle is a Dryer receptacle so I assume it is working correctly otherwise his dryer wouldnt work. He made an extension cord to plug into the dryer receptacle so the extension cord connector could be wired incorrectly , just like you think the receptacle could be the problem. so I'm pretty sure it is not the receptacle, but since I can't meter it through the internets it's my best guess
    You also mentioned that the poor performance could be due to him having 208v, I disagree since I have a MM211 and have run it on 208v- it works just as it does on 240v. This I'm positive on.
    I do not assume he knows how the MM211 works but I think he has a pretty good idea that something is wrong since he has used the welder successfully on 120v.
    I've got friends in low places
    Not to mention the FACT that my garage was wired WRONG when I first plugged MY MM211 in for the first time...IT WOULDN'T"T EVEN TURN THE FAN ON!
    Just For Home Projects.
  3. #23
    Default Update
    I want to update you guys on the issue with the 211, i sold it! I bought a 212 yesterday and let me tell you guys, the difference is night and day. I was starting to doubt all the hours of practice did anything, well they did. I have the 212 hooked in the same dedicated dryer plug as the 211, i guess the only way to describe it is the 212 is more forgiving i suppose. At this point i am just happy to have a machine that works the way i need it to. I never thought in a million years i would talk bad about a miller product but the 211 is not a great 220 machine, and thats all i have to say about that!
  4. #24
    Apr 2011
    9
    My 211 works like a champ on 240V even when I try to do something stupid. There was probably something wrong with yours that could have been fixed by the miller repair guys but glad to hear that you like the 212. FWIW: I have never used my 211 on 120V.
  5. #25
    Apr 2011
    306
    Quote Originally Posted by RAyJ View Post
    X2...except I have used mine on 120V.
  6. #26
    May 2012
    106
    Quote Originally Posted by Doughboyracer View Post
    well - I'm glad to here THIS as I just loaded a spool into my spanking new MM211 last night and intend on firing it up tonight after checking polarity setting - I think it ships set up for solid wire?
    anyway - i'll verify then fire it up - hope I don't have the issues of this unfortunate thread originator....!
  7. #27
    Sep 2012
    RVA
    4
    Default Millermatic 211 issue
    Just pulled my MM211 out of a box yesterday. Welds fantastic on 230. Much more power than I expected in a small machine.
  8. #28
    Jun 2012
    2
    I just bought a 211, it welds like a dream on 240, but you must have a 50amp breaker and a dryer plug is only good to 30amps and it can't handle the current. Your starving the machine for current and this will degrade the inverter. The outlet design and plug are low current and the internal inverter draws some current. Right ion the back of the machine it states 50 amps.
    You need to buy the right plugs and outlets, and they don't carry these at Home Depot . Grainier or McMaster Carr are your best bet.
  9. #29
    Los Angeles
    2,634
    Quote Originally Posted by moonshiner View Post
    The mm211 is not an inverter
    It will run just fine on a 30 amp circuit
    Home depot by me has 6-50r
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
  10. #30
    Oct 2006
    642
    First Home Depot does have 50 Amp outlets and plugs.
    Most importantly is the size of the wire from the breaker to the welder.
    They say that 8 ga is OK for 40 Amps ..... but if the run is too long, and extension cords are used voltage drop may be significant enough to cause problems.
    In order to insure my welders will operate as designed I installed all 6 ga wiring from the box to the welder.
    I'm picking up a MM211 in the very near future to replace a MM210 I had but was not being used as much as it would have been because of its physical size.
    I will be closely watching the MM211's performance though after hearing people are complaining about it.
    One things for certain, it won't be an input voltage problem if there are issues.
    I might just rent one for a day to see how I like it.
