Results 1 to 7 of 7
    Nov 2012
    Default MillerMatic 200 + SpoolMate 100
    Have use this gun frequently, with a 211...but never with steel wire (NOT flux-core), always with aluminum.
    Will this gun run steel wire with the 200?
    And can I use ARGON...instead of CO2, since I have Argon in abundance?
    6,750
    Steel works fine with any spoolgun, though if your a welder, you should know better on the Argon issue
    Jul 2008
    Delhi, Ontario:
    1,950
    Quote Originally Posted by buzz254 View Post
    I assume you mean Argon Mix ( 75-25 ) Not straight Argon !
    Pure Argon is for welding aluminum !
    ...........Norm
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - Horizontal Steel Band Saw
    - DeWalt Chop Saw .
    3,647
    I think the bigger question is how are you going to run the Spoolmate 100 on a MM200. Just my thoughts...Bob
    Aug 2008
    Orange, TX
    1,048
    About the only way would be coupled to an SGA 100 with a modified control cable plug to fit the MM200 4 or 14-pin spoolgun control receptacle depending on its generation.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Mar 2013
    Default will the spoolmate 100 direct conect to my millermatic 200 serial number JF946510
    my millermatic has a four pin spot for a spoolgun
    2,634
    Quote Originally Posted by mitchcv View Post
    Correct but not all Spoolguns work on all machines, you have to have the correct spoolgun
