I have been wanting to build my own turbo set ups for a few of my projects for a while ,but have had no time. I had some pieces of 304 ss 1 1/2 sch40 pipe laying around. So i decided to build a jig for my chop
saw for a a 4-1 merge collectors. im running a sync200 @ 75 amps. Also using a gas cup and back purging. This was the first test cuts on the jig and i still need to set the angles. I cleaned the pieces with a 3m disk real fast, ill trycleaning with better angles later. Any advice on getting better ? This is the first time welding stainless steel also.
Results 1 to 8 of 8
Thread: First time stainless tig.
11-07-2012, 07:55 AM #1
- Nov 2012
- 4
11-07-2012, 08:13 AM #2
- Feb 2012
- 5
You have any pictures of the cuts and welds ,would help.
11-07-2012, 08:15 AM #3
- Mar 2011
- 69
While I have no advice to offer I'm looking forward to hearing what others have to say. I need to fab up some 1/2" fuel rails winter that I would like to do out of stainless tubing and I'm a hobbiest as well when it comes to welding.
Good Luck with your project.
Brian
11-07-2012, 05:36 PM #4
- Nov 2012
- 4
Ill post some pics when im home, thought it did last night.
11-07-2012, 07:56 PM #5
- Nov 2012
- 4
heres a few pics of the two pieces i cut last night, ill post more of what i accomplish tonight.
12-19-2012, 05:20 AM #6
- Nov 2012
- 1
Hey every 1
Sometimes you need to make a tig weld in an area you can’t get to easily…like down in a hole…or a really tight corner like on a cluster weld on a 4130 chromoly airframe....or welding the corner of a drip pan from the inside. And if you have done that many times, you know that sometimes, if you extent the tungsten too far, you lose your gas coverage.
12-27-2012, 03:27 AM #7
He said hes using a gas lens, thats fine for deep joints.
03-25-2013, 11:32 AM #8
- Mar 2013
- Ohio
- 2
What's your flow rate and pre/post flow settings? It looks like the weld could stand to see some more gas coverage.
