Results 1 to 5 of 5
    Dec 2012
    Sweetwater, TX
    201
    Question Which outlet for dynasty 200dx?
    Going to start rewiring the new building on the lot next door we purchased. It was previously used as a welding shop so the wiring should be ok. I just don't like the placement of some of the plugs.
    I'm moving an existing 240v oulet in my shop to a more central location not to mention the current outlet was in need of replacement. The building already has a 50amp breaker dedicated to the plug.
    What style plug does the dynasty 200dx us for 240v, straight or angled?
    Which one?
    http://www.lowes.com/pd_409855-43469...t_avg_rating|1
    Or
    http://www.lowes.com/pd_246883-1571-...t_avg_rating|1
    Does the dynasty come with a plug on it or bare wires?
    can some one post a picture of it?
    Have a gift card to lowes I can use to get the outlet as well as some outdoor rated covers for my 120v outlets to prevent spraying them when grinding.
    Thanks!
    Jul 2010
    Salem, NJ
    297
    You just need a 30 amp outlet. I have mine off of a 50 amp straight bar as in your first one. I use that one because it is the most universal outlet that a homeowner has.
    Nov 2012
    Northern Arizona
    563
    I've got all my equipment standardized with NEMA 6-50 ends. I have adapters built to allow me to plug my equipment into other types of receptacles when I'm not at the shop. IIRC, the dynasty will come with a bare pigtail and allow you to add your own plug.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Dec 2012
    Sweetwater, TX
    201
    Quote Originally Posted by elvis View Post
    How many wires is the pigtail 3 or 4 ?
    Nov 2012
    Northern Arizona
    563
    it will run on 3-phase so it should be 4-wire conductor. You can just pull off the extra (usually red) wire to run it on single phase. Depending on your situation you also might want to wire up a adapter to run it on 115v power. It will auto link for the right power source, which is handy.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
