    Nov 2011
    21
    Default helium increase mig alum capacity?
    I know from reading different forums that if helium is used with a TIG instead of argon it increases capacity...
    Q-does the same apply to a MIG with spoolgun?
    Eric
    6,752
    Thats Helium and Argon mixed. so sure you'll get a hotter arc. However helium is freaking expensive and in short supply. Best have a real need and deep pockets.
    For Mig welding sure but again its a Helium / Argon mix
    Nov 2012
    Washinton
    56
    If you are having trouble with contaminants or working on thick sections then it works great and is worth the price. I have seen this used most often on Alu. dump truck bodies.
    Nov 2011
    21
    So it is a mix of Argon and Helium?
    I was under the impression that it was straight Helium!
    I do not yet have the need for this but am trying to learn from those that know
    Nov 2012
    Washinton
    56
    As much as Praxair is a pain in my mind at least they have info. and the blends they talk about are available from most all LWS's. Read below:
    http://www.praxair.com/praxair.nsf/d...ILE/P-8358.pdf
    Nov 2011
    21
    That's great thanks for the link!
