Results 1 to 2 of 2
    Nov 2012
    3
    Default Tig welding pedals universal? RCF-23GD25A
    I found a welding pedal on eBay it has 2 plugs one is an older three-pronged Twist style and the other has straight pins. do these pedals to use both plugs at the same time or one or the other?
    Oct 2004
    Edmonton, Alberta
    8,325
    The 3 pin is for resistance control, whilst the 2 pronger is for contactor control.
    You could easily whack the plugs off and put a 5 or 14 pin on the cable and do the same thing for another machine.
