Results 1 to 2 of 2
    Nov 2012
    Default miller legend AEAD 200le
    My welder works fine but the generator only works on the welder side. When u turn to power and rabbit run i get no voltage at all. Looked in trouble shooting and its pointing towards circut board. Not sure any suggestions
    Nov 2012
    Montana
    12
    Mine does the same thing so I got the manual and its factory built that way its just the way it works if you got juice at them plugs when the machine is at high idle it would create like twice the current and you'll burn up any tools you try to run
