I have a6-7 yr old miller bobcat with the 20 hp Kohler engine. I need to change oil. Do any of y'all have a cross number to a Fram or STP oil filter that is suitable. Thanks
Results 1 to 10 of 10
Thread: bobcat oil filter
11-03-2012, 08:49 PM #1
bobcat oil filter
11-04-2012, 06:35 AM #2
Member
- Aug 2010
- Chesapeake, Va
- 96
fram Part Number PH8172 the oem kohler number is 12 050 01 .
Miller pro 300 perkins diesel, 30 amp spool gun , Hobart 210 with spool gun, Thermal dynamic pak master 75 all mobile all ready to go.
11-04-2012, 11:46 AM #3
Or you call your parts store they should know
11-05-2012, 04:12 PM #4
- Oct 2012
- 12
bobcat oil filter
Don't use fram. Worst oil filters on market. Go to napa or other good parts store and get a wix or cassite. Both are very good
11-05-2012, 06:08 PM #5
Member
- Aug 2010
- Chesapeake, Va
- 96
I use wix on all of my good equipment they make really good filters and there are not that expensive. I know the wix filters when I had my bobcat were $5.75 a piece. I hate fram but they are better then the stp filters i have sheared off 2 trying to get them off of trucks and the filters were installed correctly but the really thin metal crushes under a filter wrench.
11-05-2012, 06:18 PM #6
I agree 150% to wix. Napa and Carquest are just rebadged wix
Never Satisfied
Millermatic 211
Maxstar 150STL
Metabos
Kennedy Maintenance Pro Full
Makita Cordless 18v Li-Ion
Stihl TS 420
Timfrank88@live.com
11-05-2012, 06:20 PM #7
- Feb 2009
- Lodi, CA
- 1,132
You should be able to go to any decent auto parts house, with your current filter number or engine number, and drive away with the correct filter, spark plugs, etc. etc If your local parts house can't do this, you need to find another one. You can even oftentimes just plug the number into google, with no brand name, and come up with the correct cross-references. It's that easy
11-06-2012, 11:50 AM #8
Napa 1056. Good quality filter. Use on all my Kohlers' with great results.
Campbell Hausfeld 110V MIG
Jo Ann Fabrics Hot Glue Gun
11-06-2012, 04:59 PM #9
- Oct 2012
- 12
bobcat oil filter
Napa is a wix filter they are very good
11-06-2012, 06:23 PM #10
- Mar 2012
- 20
AMSOIL #34 filters work also but they Re about twice the length. I run them in my tb302.
