Results 1 to 10 of 10
    Jun 2012
    23
    Default bobcat oil filter
    I have a6-7 yr old miller bobcat with the 20 hp Kohler engine. I need to change oil. Do any of y'all have a cross number to a Fram or STP oil filter that is suitable. Thanks
    Aug 2010
    Chesapeake, Va
    108
    fram Part Number PH8172 the oem kohler number is 12 050 01 .
    Lincoln Vantage Kubota diesel 30 amp spool gun , Hobart 210 with spool gun, Thermal dynamic pak master 75, miller 304xmt all mobile all ready to go.
    Nov 2012
    Floresville, Texas
    Or you call your parts store they should know
    Oct 2012
    19
    Don't use fram. Worst oil filters on market. Go to napa or other good parts store and get a wix or cassite. Both are very good
    Aug 2010
    Chesapeake, Va
    108
    I use wix on all of my good equipment they make really good filters and there are not that expensive. I know the wix filters when I had my bobcat were $5.75 a piece. I hate fram but they are better then the stp filters i have sheared off 2 trying to get them off of trucks and the filters were installed correctly but the really thin metal crushes under a filter wrench.
    Jan 2012
    Metro Detroit, MI
    182
    I agree 150% to wix. Napa and Carquest are just rebadged wix
    Never Satisfied
    Millermatic 211
    Maxstar 150STL
    Metabos
    Kennedy Maintenance Pro Full
    Makita Cordless 18v Li-Ion
    Stihl TS 420
    Timfrank88@live.com
    Lodi, CA
    1,244
    You should be able to go to any decent auto parts house, with your current filter number or engine number, and drive away with the correct filter, spark plugs, etc. etc If your local parts house can't do this, you need to find another one. You can even oftentimes just plug the number into google, with no brand name, and come up with the correct cross-references. It's that easy
    Jul 2011
    NE Ohio
    25
    Napa 1056. Good quality filter. Use on all my Kohlers' with great results.
    Campbell Hausfeld 110V MIG
    Jo Ann Fabrics Hot Glue Gun
    Oct 2012
    19
    Napa is a wix filter they are very good
    Mar 2012
    28
    AMSOIL #34 filters work also but they Re about twice the length. I run them in my tb302.
