Results 1 to 9 of 9
    Nov 2012
    Granville, ohio
    13
    Default AEAD-200le auto idle / hertz issues
    i recently purchased a nice old aead-200le. after a little tlc, the motor runs great, puts out 120v at the the front 60hz outlets when checked with my hertz meter, but it seems to jump to 108hz or so once and awhile. On another note it idles up when the auto idle switch is thrown, but never idles back down. i have read some similar posts on here but haven't quite gotten it figured out yet, i have the owners manual but no technical manual yet.
    thanks in advance for any suggestions.
    Oct 2004
    Edmonton, Alberta
    6,752
    There is one plug that runs in at 100 hz that can be used while welding high idle,
    The other 2 are are for low idle at 60HZ
    Sep 2012
    seaford de
    335
    I have the same problem with mine. I have just been welding with it at high idle. I just have to hit the switch for it to idle down. Im probly gona replace the idle control board if i can find one
    Oct 2004
    Edmonton, Alberta
    6,752
    Quote Originally Posted by weldonwelding View Post
    Tthat or replace the 2 little 8 amp 200 volt TO220 SCRs on the idle board....
    Sep 2012
    seaford de
    335
    Quote Originally Posted by cruizer:295682
    Where would i find those?
    Nov 2012
    Granville, ohio
    13
    I have read some other threads on the pc1 board being the fault, i may try the replacement of the parts cruizer suggests, just have to find out where to get the parts. Anyone ever see a technical service manual for one of these? seems like a good reliable machine. I have checked the hertz coming out of the dual 60hz sockets and that is where i get the fluctuations from 58hz to 108hz. i have checked the rpms to make sure it is at 1850, just don't want to burn up any sensitive equipment. thanks
    Oct 2004
    Edmonton, Alberta
    6,752
    Remove right side cover, you'll see a couple of boards, your after the front one (towards the front panel), Inside the fingered square heat sink there is 2 scrs. these are the ones to replace to get your auto idle back working again.
    I tend to replace them with: 2 of 10 amp 250 volt TO220 package SCR, you can get them from Digikey, or Newark.
    You'll need a soldering gun, some electrical solder, and a small roll of solder wick to remove the old solder.
    Nov 2012
    Granville, ohio
    13
    Cruizer that is exactly the info i was hoping to find. I was having a hard time locating the stock 8.5a scr's, i was thinking 10a would work well.
    I repaired an old Roughneck 1E from some info i saw on this forum as well, soldered in new diodes.
    I appreciate all the advice guys.
    Nov 2012
    Granville, ohio
    13
    Default update
    Got the 2 new scr's and installed. Unit will idle up when a load is applied, but still no idle down when the load is off. Anyone know of a way to troubleshoot my idle control board, or am I doomed to by an upgrade board unit?
Tags for this Thread
