Results 1 to 5 of 5
Thread: Re:
    Default Re:
    Are there any pipeline welding jobs that are not x-ray? And if so how would i get in contact with them?
    Default pipeline welding
    Are there any pipeline welding jobs out there that are not x-ray and if so how would I go about getting those jobs?
    Dec 2008
    Arizona
    812
    Not in this day and age. With pipeline failures of recent years PHMSA and DOT are only going to get stricter on operators. Many pipelines don't require 100% x-ray, but are usually at least 10%. Besides, why fear the x-ray? It's easier to pass an x-ray than a destructive test used to qualify!
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Default Re:
    Well I'm not afraid of the X-ray I've passed several under the 1104 code I used to build meter tubes but it was with hardware and fluxcore jw if X-ray is any harder with stick
    Default Re:
    Bcuz I plan on moving to the pipeline or compressor station or possibly some gas plants
