    Nov 2012
    Default Stainless square edge butt weld Sched. 10, no gap, one pass , fusion.
    What do you think? Can you? How would you recomend doing it?
    Dec 2008
    west central Florida
    135
    Quote Originally Posted by garm1248 View Post
    What size pipe? Why do you want to do this?
    Jun 2012
    3
    Yes you can fuse it, but why not just add some tig rod its easy.
    Jul 2010
    Salem, NJ
    294
    I do a lot of sanitary welding and I do butt and run (fuse). It is very easy and it holds 250 psi without problems in 4 years. But if the joint is not 100% square, use filler wire. I run .035 tig wire. Not mig wire.
