Results 1 to 6 of 6
Thread: Cruizer
    May 2008
    Ashmont, Alberta
    36
    Default Cruizer
    Hey Jeff I was just wondering what kind of meter your using to measure hz. I have a clamp on Greenlee 950 (if that helps any). I can only get a hertz reading if I clamp the meter around one wire on a cord I rigged up and plug in my rod oven. I tried plugging the leads into the outlets but don't get a reading that makes sense.
    Oct 2004
    Edmonton, Alberta
    8,350
    Nope doesn't make sense, Stick the probes into a receptacle, What your wanting is AC frequency.
    Feb 2005
    N.E. SD
    1,381
    I have an Ideal meter that reads Hz, but it goes crazy on a generator that isn't loaded.
    So, I put a cord on a panel mount Freq meter and just plug it in.
    Jeff
    Mar 2011
    torrington, connecticut
    22
    Default frequency
    just a quick refresher please. what is the proper frequency for proper welder rpm for a welder/generator. thanks, i know you have mentioned this before just don't remember what thread.
    Oct 2004
    Edmonton, Alberta
    8,350
    62.5 hz small gasser, like Lincoln 305, Miller 302
    60.5 - 61 hz for a Lincoln Classic, Vantage, Miller pipepro350
    61 - 62 hz for Miller pipepro 304, Pro300
    PA
    374
    My poor mans frequency meter method is to use my Kill-a-watt meter.
    Drawback is that it only good for 120 VAC.
