Results 1 to 10 of 12
    Default My ground cable is getting very hot
    I have check all the pulgs and the are good an tight I have put on a c clamp on the ground cable but its still gets hot and not welding right any Ideas ?
    Mar 2006
    Corunna Ont, Canada
    455
    Well a little more info will be needed to help,
    What machine, what process, amps ?
    Sounds like your cable connection at your ground clamp is dirty or corroded or even too light of a clamp or cable is too small for the amps you are you using?
    Railmen
    2007 Trailblazer 302G
    2004 Invision 354MP
    1999 60 series feeder
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    older Hobart hefty wire feeder
    Hyperthrem 600
    Maxstar 150S(such a cute welder)
    had and sold........
    2003 XMT 304CC/CV
    1947 Lincoln SA200G short hood
    1963 Lincoln SA200G
    1975 Lincoln SA200G(best machine ever had )
    1970's Lincoln SAE400G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
    Oct 2004
    Edmonton, Alberta
    8,176
    Only is going to get hot, if....
    - The cable is too small for the current applied
    - Wrong ground clamp, ie, a non brass version
    - A connection is loose, whether it be a crappy bond to the material being welded
    on or a loose cable connector
    Oct 2007
    Cave Creek Az
    1,048
    Almost guaranteed that it is the cable connection to the ground clamp. Replace it with the brass version and you get a much better connection with the ball screw arrangement.
    Apr 2012
    Western Pa.
    296
    Yep. I agree. Run my 350-p since last fall, just put off replacing cheap OEM clamp. Grabbed it couple weeks ago was hot as fire (all bolts tight)
    Replaced it with brass one. No Heat.
    Can't believe u pay that much for a welder & it comes with that cheap clamp.
    Oct 2012
    4
    Solder the cable into the clamp.
    Shipyards do it,works great.It also helps keep the water out when welding in the rain.
    Oct 2007
    Cave Creek Az
    1,048
    Just my experience, but I have found the ball screw to be better than solder. Soldered connection, especially if they see a lot of temp change over time become high resistance connections. I have, over a period of time, cut off all my soldered connection due to failure. IMHO not a great way to go.
    Oct 2009
    Reno, NV
    299
    My very first thought when I read that your CABLE gets hot is that the cable is under sized for the amps it is having to carry. If all the connections are right/tight...then my second thought is....wait for it....the cable is too small!
    Don J
    Reno, NV
    Never pick a fight with an old guy. Old guys are too smart to fight and get hurt. They'll just kill you and get it over with.
    Jun 2012
    Tracy, CA
    221
    I would think the engineers who design these welders are smart enough to include a cable capable of handling the intended current.
    My first thought would be something either wore out or became loose. I would not guess the cable isn't big enough. If it once worked but now doesn't, something changed. Short of the cable being damaged, I wouldn't expect a cable to change.
    I could be wrong. That's just how I troubleshoot.
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    SuitCase® X-TREME™ 12VS
    Multimatic™ 200
    Millermatic® 211 Auto-Set™ w/MVP™ (Sold)
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Victor Oxy/Acetylene Set
    Dec 2011
    419
    Feel up your cable, welding cable that is, especially close to the connector and the work clamp, You are looking for soft, limp areas. It can mean that the cable inside the insulation is breaking off likely due to many flexings in its life. Cut it off and make a new connection. Also check along the cable for any place where it may have been jammed, it can give the same result. Also most of the above and more info might be useful.
    Meltedmetal
