Results 1 to 10 of 20
    Apr 2012
    Queen Creek AZ
    38
    Default kalamazoo bandsaw ??
    I have an opportunity to pick up a kalamazoo h9aw bandsaw great shape. For $900
    Im looking for reviews on this or experiences with this saw.
    What little bit i could find is, its usa made and commercial grade possibly late 80's saw. Parts still available.
    Thx for anything
    Oklahoma
    727
    Lightbulb
    Quote Originally Posted by Jobpump53 View Post
    Thx for anything
    I dont know about the bandsaw but I have used other Kalamazoo equipment.
    All were well built.
    I personally have Kalamazoo 6" beltsander and it is excellent.
    Griff
    Mar 2008
    Long Island NY
    15
    I have one from the early 80's. I bought it used for $500 from a machine shop next to me that went out of business. This saw is built like a tank. It has not let me down in the two years i have owned it. Parts are still available thruogh Clausing and other aftermarkets as well.
    Apr 2012
    Queen Creek AZ
    38
    CD - how does your saw cut? This saw cuts at a slight angle i would gues approx. 1 degree angle.
    I guess my question is- does your cut very accurate and true or is this the nature of horizontals? The seller says its always been this way
    Thanks i appreciate the response.
    Aug 2010
    Chesapeake, Va
    108
    We have a kalamazoo at our shop and that thing probably has 4,000 hours on it and it works great. They bought it used out of the paper about 15 years ago for $500 there has been many days where I run it 10 hours aday 1/2 wall tube or 3/4" 5by 5" angle with it. It never skips a beat we have the lennox blades work it and I can make about 400 cuts with one before it is dull or breaks. Does this one have the water cooler or any extra blades?
    Lincoln Vantage Kubota diesel 30 amp spool gun , Hobart 210 with spool gun, Thermal dynamic pak master 75, miller 304xmt all mobile all ready to go.
    May 2010
    Central CA
    784
    I have had 2 of those saws. The first was a small saw 8-10" flat bar. I used it from '65 to '89 then it went an other shop in Roseville.
    The one I have now, I got used in '89 and it still works great.
    The blades can be made to cut straight by the use of the rollers. They are on an ecentric.
    The only draw back to the Kalamazoo is it only cuts angles one way. Therefor you have to rotate your iron to matching angles.
    Good Luck,
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
    Apr 2012
    Queen Creek AZ
    38
    I ended up buying it. Its super clean and in great shape. It is liquid cooled with a new pump. It came with 7 blades some of different widths and teeth count ( need to do research on applications)
    I paid $900 every thing i researched showed that was mid range on the price. ?.
    Used machinery is more expensive out west where it is not as abundant. I think you got a fair deal on a clean machine.
    Apr 2012
    Queen Creek AZ
    38
    I have noticed that. I have been looking for some time now. This caliber of machine has been hard to come by, thats why i jumped on it while i ha the chance.
    I believe the reason it is cutting at an angle is do to it having a 3/4" blade and it requires a 1" blade per manufacturer and the guide rollers. Just order proper blade crossing fingers!
    You got the Kalamazoo for $900? The price is just right. You may want to check the bandsawmanuals.com . You can get free manuals for your Kalamazoo.
