Thread: steel margins?
    Jul 2012
    16
    Default steel margins?
    What kind of margins should be put on steel when quoting a job? Thanks.
    Aug 2010
    Chesapeake, Va
    108
    20% if your confident in your estimate 30% if there is a gray area 50% if you did a drive by estimate and never slowed down.
    Lincoln Vantage Kubota diesel 30 amp spool gun , Hobart 210 with spool gun, Thermal dynamic pak master 75, miller 304xmt all mobile all ready to go.
    Aug 2004
    Milan Michigan
    1,806
    It depends on if you are buying your steel in quantity 5-10,000 lbs. where your bigger fab shops are buying theirs or are you buying from the next tier down that is a small company.
    You have to have an idea what your competition is selling their steel for.
    For years I bought from the second tier and bought as I needed so I was not getting the best deal and now I buy from the same company that they buy it from so I save about .10 - .20 cents a lb. but I keep an inventory and buy 5-10,000 lbs. at a time.
    Jul 2012
    16
    Awesome information! Thank you so much.
