Results 1 to 10 of 11
    Oct 2012
    Danielsville, PA
    6
    Default MM175 doesn't power up.
    Hi, I'm new to welding, I just finished setting up my used MM175. I plugged the machine in and turned it on just to see if the feed rollers would turn. After pushing the switch to turn the machine on it remained dead. I checked the voltage at the outlet and that is correct across the 2 hot lines, there is power to the reset on both legs. I have no lights on the circuit board (green & red) if anyone has any idea what could be wrong I'd appreciate hearing from you, thankyou.
    Oct 2004
    Edmonton, Alberta
    6,755
    Unit has a transformer/fan motor, what happens even out of the box the wires to that transformer, come loose. Very popular problem with this type of setup.
    Oct 2012
    Danielsville, PA
    6
    I failed to mention I did check connections, perhaps not good enough, I'll have to recheck them again.
    Oct 2004
    Edmonton, Alberta
    6,755
    You didn't check the connections at the fan motor, I bet, 2 wires to run the fan motor and 2 to power everything else
    Oct 2012
    Danielsville, PA
    6
    Unfortunately I did check everyone of the connections. At this point I'm figuring its the circuit board.
    Oct 2004
    Edmonton, Alberta
    6,755
    NO lights, means no power, merely check for 24VAC on the 2 white leads comming off that fan motor. Bet its that unit, very common for failure there,
    Oct 2012
    Danielsville, PA
    6
    Ok, I unplugged the connector that connects the PC board to the fan motor, on the 2 white leads I got 0 VAC, ON THE 2 black wires in the same connector I got 14.8 VAC. It appears the fan isn't getting the correct voltage from the PC board.
    Oct 2004
    Edmonton, Alberta
    6,755
    You check the wires at the TRANSFORMER, Yankin the connector at the circuit board won't tell you anything.
    Oct 2012
    Danielsville, PA
    6
    I just checked the white wires coming out of the transformer and it read 0VAC, does that mean the fan/transformer is bad? Sorry for not totally understanding all this but electronics are not my forte, and also thank you for your patience.
    Oct 2004
    Edmonton, Alberta
    6,755
    Yes, this means that the fan motor/control transformer is bad. Same thing I've been saying all along.
