Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: T1 Transformer
  1. #21
    6,750
    Yep, You'll see a couple of wires together in your t1 transformer with #'s 15 & 6. see if they are closed, if not you could always jumper them out.
  2. #22
    Oct 2012
    11
    Default T1
    Quote Originally Posted by weldbay View Post
    I think the 130 has an overlaod protector protector TP1 at the T1 transformer, if it is faulty fan will run but not weld output.
    Here is your sechmatic.
    http://www.millerwelds.com/om/o1316f_mil.pdf
    Thanks much, what does the italicized numbers, (1, 2, 3, 5, 15, etc) relate to?
  3. #23
    6,750
    There are #'s on the wires.
  4. #24
    Oct 2012
    11
    Default T1
    Machine started working after I removed the blade connector from the overload componant. Looking at the side of machine, the wire at top of the overload componant was removed to check voltage and when I reconnected the lead and pressed the trigger on gun the drive motor started working.
    So much for a Authorized Repair facility
  5. #25
    6,750
    Well thats FANTASTIC NEWS!!! Its tough to t-shoot over the net especially when there is wires off vital components.
    But I'm super glad its working again!
