Can I run a 22A feeder off my Millermatic 200 or Syncrowave 250DX? I want to set up a feeder for dual sheild. Both have the 14 pin connector.
Thanks,
Dave
Results 1 to 5 of 5
Thread: MIllermatic 200 & 22A Feeder
10-25-2012, 08:16 AM #1
- Mar 2007
- 14
MIllermatic 200 & 22A Feeder Compatable ?
10-25-2012, 06:46 PM #2
As far as I know you can't run a 22a on the syncro as it is a cc machine & you need cv for mig. Why wouldn't you just run the dual shield in your mm200?
MM250
RCCS-14
10-25-2012, 07:36 PM #3
- Oct 2007
- Cave Creek Az
- 803
I suppose you could figure out how to run a feeder off your MM200, but why would you want to?
10-25-2012, 09:12 PM #4
Yes, the 22A will run off the MM200 by simply plugging in the 14-pin and connecting the weld output cable to the (+) receptacle on the MM200 same as you would for the Spoolmatic 3 spool gun.
But I have to ask as MMW did - why not just run the dual shield off the MM200? Do you want/need to swap back and forth often or quickly?MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
10-26-2012, 07:04 AM #5
- Mar 2007
- 14
Thanks for the reply. I do use it for dual shield. I just thought maybe I could hook up a feeder and keep from switching back and forth.
Dave
