    14
    Default MIllermatic 200 & 22A Feeder Compatable ?
    Can I run a 22A feeder off my Millermatic 200 or Syncrowave 250DX? I want to set up a feeder for dual sheild. Both have the 14 pin connector.
    Thanks,
    Dave
    1,895
    As far as I know you can't run a 22a on the syncro as it is a cc machine & you need cv for mig. Why wouldn't you just run the dual shield in your mm200?
    Cave Creek Az
    1,047
    I suppose you could figure out how to run a feeder off your MM200, but why would you want to?
    Aug 2008
    Orange, TX
    1,216
    Yes, the 22A will run off the MM200 by simply plugging in the 14-pin and connecting the weld output cable to the (+) receptacle on the MM200 same as you would for the Spoolmatic 3 spool gun.
    But I have to ask as MMW did - why not just run the dual shield off the MM200? Do you want/need to swap back and forth often or quickly?
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    14
    Thanks for the reply. I do use it for dual shield. I just thought maybe I could hook up a feeder and keep from switching back and forth.
    Dave
