Background on my problem: I weld this one particular part at work pretty frequently. It's an L-shaped bracket with a hole in it where a pin goes through it at a right angle. The bracket is maybe 3/16" thick and the pin is about 1" in diameter. Both pieces are carbon steel, nothing special. Both pieces are adequately cleaned. The process is TIG welding with a Miller Syncrowave 250. The equipment is functioning just fine. Using ER70S fill rod.
We have cracking issues sometimes with the welds on these. It shows up immediately. You have to make three beads to complete the weld, and it almost always shows up in the third and final bead, sometimes the second one. You'll just wind up with a crack that runs the length of about half the weld. The only thing that seems to help it is to turn down the amps on the welder, but sometimes even if you turn it way down (we are usually welding around 200A) and you are at 175A it still cracks. If you run over it a second time with more fill rod it's fine.
The weird thing is some nights it's not an issue at all, and sometimes it seems to happen on every fifth or sixth part. Anyone have some suggestions on what's going on here? It slows me down getting work done, because I have to pause after every part and look at it and be real positive it doesn't have a crack rather than just pulling it out of the jig, tossing it on the table, and moving on to the next piece. I could be turning out a lot more of these things if I knew we had the problem licked.
Thanks to all in advance,
Tom
Results 1 to 10 of 10
Hybrid View
10-24-2012, 11:46 AM #1
Member
- Feb 2010
- Indiana
- 49
TIG weld cracking issues, carbon steel - heat cracking?
10-24-2012, 01:05 PM #2
maybe this will help
http://www.lincolnelectric.com/en-us...ldcracking.pdfEd Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
10-24-2012, 01:47 PM #3
Could the pin be leadloy or sulfurized?
Ask for the real material alloys so you can choose a more appropriate filler.Nothing welded, Nothing gained
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
10-25-2012, 10:34 AM #4
Member
- Feb 2010
- Indiana
- 49
Thanks Ed and shovelon. Ed, that article is GREAT! I will see if I can find out what the makeup of the steel is that we're welding, but the article pointed out several things that I can try that might be the problem or contributing to it.
Last night for some reason I started thinking about torch angle and how getting lazy with that might be affecting things, so I got real careful about it and that seemed to help. I also noticed "high speed passes" might be a problem, and I can definitely get moving fast at times, so I'll look out for that. Plus, I see that welding straight down on a right-angle joint can be a problem, and the jig kind of makes you want to weld that way just because it's easier to clear obstructions and move quickly if you do. Last, it looks like turning down the amperage might be something to consider, although I'm not sure how low I can go and still get appropriate penetration. My day guy (who is essentially my welding boss and has several years of experience) tells me to try and not go below 200A, but sometimes that's the only thing I can do to lessen or stop the problem. I do notice that my welds are concave, and I didn't know that was incorrect on that type of joint. I've noticed before when backing off the amps that the weld does become more convex.
Thanks for the information,
Tom
10-25-2012, 01:09 PM #5
Member
- Sep 2012
- 91
Not sure if this applies but one thing you didn't mention is whether the piece you are welding the L-shape to is also 3/16" thick. Even if both pieces are the same material you can still get cracking if one of the pieces has a significantly greater mass than the other at the weld site. In that situation the two pieces will cool at different rates putting stress on the weld.
10-25-2012, 01:54 PM #6
Member
- Feb 2010
- Indiana
- 49
Matrix, yes, the pin that gets welded into the hole in the L-bracket is 1" in diameter approx, so there's a significant difference there. It seems I've got several things working against me here and it may just come down to careful moderation of heat and my welding technique.
10-25-2012, 06:57 PM #7
- Apr 2012
- Western Pa.
- 102
One thing to consider, hot cracking, can come from welding at to high temp along with to fast travel speed. If your weld is also concave this is a possibility.
Welding to hot is just as bad as to cold. Just because u weld at high amps doesn't assure proper penetration. It comes as much or more from proper technique with correct amps. Watch & work the front edge of puddle to achieve good penetration, adjust travel speed to allow rear of puddle to fill in for proper weld thickness.
Also welding down is difficult to acquire good penetration & weld thickness.
A good weld is not just laying a bead. It comes from allot of thought & preparation i.e. Metal thickness, metal type, type of joint, angle, filler metal, type of gas, amps,torch angle, travel speed etc. Put it all together with a little practice & your welds will be great.
Just a thought, hope it helps.
....a couple pictures may be worth a thousand words....
