Results 1 to 3 of 3
    Dec 2011
    20
    Default 70 series 24v wire feeder drive rolls
    I intended to use 0.8 mm wire on my 70 series wire feeder.I am checking on the ordering data sheet there is no 0.8mm drive roll.The chart only starts with 0.9mm drive rolls.
    Could someone help me get the part number for the 0.8mm drive roll kit
    Jul 2010
    Four Flags city
    298
    74 series 0.8mm(.030) V groove drive rolls kit number is 151025.
    Dec 2011
    20
    Quote Originally Posted by big mike View Post
    Thanks Big
