Thread: Cheater Lens
    S.W. Missouri
    143
    Default Cheater Lens
    Does anyone know which of the newer AD hoods will accept the thicker glass cheaters?
    I know the Hobart won't as the clips that hold it won't accept the thicker glass lenses.
    I've been shopping for a new hood and that's one spec they never mention. and no there is no way I can live with the plastic ones that the first time you wipe off they are so scratched you can't see anything.
    Trailblazer 302
    Lincoln SP-135-T
    Hobart Stickmate AC/DC
    Smith torch
    Spoolmatic 30A
    I'm pretty sure alot of the Miller ones do. I think all of them might actually.
    Oct 2011
    Minnesota
    23
    Quote Originally Posted by shortarc View Post
    How thick are the glass cheaters? I tried to search and the thickness wasn't specified in the first couple I found. I use a 1.5 diopter Hobart cheater and it really helps. The glass maybe a good option if it gets scratched.
    S.W. Missouri
    143
    Quote Originally Posted by pin2hot View Post
    just went out to the truck and measured one. It's .285 or about 9/32.
    Trailblazer 302
    Lincoln SP-135-T
    Smith torch
    Spoolmatic 30A
    Oct 2011
    Minnesota
    23
    My Hobart cheater is 4-1/4 x 2 x ~5/32 and just fits in the slot in a Speedglas 9100V. No way would 9/32 fit. The 9000 series speedglas supposedly lets you put a cheater under the front cover plate. I don't think there is a dedicated slot for a cheater, though. But I've been wrong before, way more than once.
    Oct 2012
    Northeast PA
    3
    I use a Hobart 2.50 in my Hobart auto-arc hood. Works great for me. Welding is much tougher without it. Have tried using glasses under the hood without the cheater but its not as good for me doing mig.
