Thanks, I'll check it as soon as i get a chance and let you know. Thanks for the tips, hope i can get to the bottom of this.....
Results 11 to 14 of 14
Thread: welder does not come on!
10-22-2012, 10:07 PM #11
- Oct 2012
- 6
10-23-2012, 10:29 PM #12
- Oct 2012
- 6
Not sure the proper procedure for checking for 240 volts on the 2 legs with my multimeter, I could use a little instruction.... thanks!
10-24-2012, 09:11 AM #13
Often your probes won't go all the way into the wall receptacle, so what I do is stick the machine plug in part way, and very carefully meter those plug pins in Volts AC
10-24-2012, 09:07 PM #14
- Oct 2007
- Cave Creek Az
- 796
Check from each leg to neutral (115vac each) the check across the blades for 230vac.
