Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Oct 2012
    6
    Thanks, I'll check it as soon as i get a chance and let you know. Thanks for the tips, hope i can get to the bottom of this.....
    Oct 2012
    6
    Not sure the proper procedure for checking for 240 volts on the 2 legs with my multimeter, I could use a little instruction.... thanks!
    Oct 2004
    Edmonton, Alberta
    8,227
    Often your probes won't go all the way into the wall receptacle, so what I do is stick the machine plug in part way, and very carefully meter those plug pins in Volts AC
  4. #14
    Oct 2007
    Cave Creek Az
    1,051
    Check from each leg to neutral (115vac each) the check across the blades for 230vac.
