Results 1 to 10 of 14
    Oct 2012
    6
    Default welder does not come on!
    I have a Miller 210, put 1 spool of wire through it and it always worked great. I moved from California to Colorado 3 years ago and just now was able to use welder. I plugged it in and turned on the switch and........ nothing! I checked the power source and then opened up the welder. There is power to the switch and out the other side. There is power to the fan and the leads going to the transformers but nothing comes on..... Any ideas???? Help!
    Oct 2004
    Edmonton, Alberta
    8,330
    Quote Originally Posted by Ted View Post
    Post a serial#, so we can look at the correct diagram.
    Oct 2012
    6
    Sorry, new at this.... serial number is LC558486 and if it helps or not the stock number is 907046. Thank you in advance for any help or direction you may have.
    -TED-
    Oct 2004
    Edmonton, Alberta
    8,330
    Maybe a gun problem, jumper the machines trigger terminal with a piece of mig wire
    Oct 2012
    6
    Thank you, i'll go try it...... Well, that didn't work, all I got was silence again. does anything go wrong from just sitting for almost 4 years or traveling 1100 miles on a truck? This thing is in brand new condition and was always kept inside. Got any ideas for my next step?
    Oct 2004
    Edmonton, Alberta
    8,330
    Pretty simple machine, Is your power correct?
    Odd that your contactor is dropping out, thats why I'm thinking that you don't have a complete 230 Vac to run the unit.
    Oct 2007
    Cave Creek Az
    1,068
    Need to spend a few minutes with multi meter and determine if you have the right power at the outlet first, then hopscotch up the machine a wee bit. I would see if there is another outlet you can try the machine on first.
    Oct 2012
    6
    i checked power with multimeter and got 121 volts on each leg at the outlet and also through the welder on / off switch....
    May 2009
    Central North Carolina
    150
    You should be checking for 240 volts across the two hot leads, not from each to ground. Check the power at the outlet first, then check inside the welder with it plugged in. With the welder turned on, also check the output side of the power switch. A poor electrical connection can still give you good voltage readings if there is no load, but the voltage will drop significantly after the poor connection when a load is connected.
    Charley
    ______________________________
    Miller MM252
    Miller Bobcat 225NT
    Miller DialArc HF & DIY Cooler
    2 Miller Digital Elite and 3 Fixed Shade Helmets
    2 O/A torch sets
    DeWalt 18 volt 1/2" Driver/Drill
    DeWalt 18 volt 6 1/2" Metal Saw
    DeWalt Porta Band & SWAG Offroad V3 Table
    Milwaukee 8" Dry Cut Saw
    Milwaukee 14" Dry Cut Chop Saw / Delta Stand
    Milwaukee 9" Grinder
    2 Milwaukee 4 1/2" Grinders
    Milwaukee Hole Hawg 1/2" Drill
    Wallace 5 Ton Gantry
    Too many hand tools
    Oct 2004
    Edmonton, Alberta
    8,330
    Unfortunatly, as Charley said, that reading you took means squat. just tells me that you have power on the receptacle, doesn't tell me if its on the same phase or not.
