I have a Miller 210, put 1 spool of wire through it and it always worked great. I moved from California to Colorado 3 years ago and just now was able to use welder. I plugged it in and turned on the switch and........ nothing! I checked the power source and then opened up the welder. There is power to the switch and out the other side. There is power to the fan and the leads going to the transformers but nothing comes on..... Any ideas???? Help!
Results 1 to 10 of 14
Thread: welder does not come on!
10-20-2012, 02:27 PM #1
- Oct 2012
- 6
10-20-2012, 04:19 PM #2
10-20-2012, 09:14 PM #3
- Oct 2012
- 6
Sorry, new at this.... serial number is LC558486 and if it helps or not the stock number is 907046. Thank you in advance for any help or direction you may have.
-TED-
10-20-2012, 09:27 PM #4
Maybe a gun problem, jumper the machines trigger terminal with a piece of mig wire
10-21-2012, 03:08 PM #5
- Oct 2012
- 6
Thank you, i'll go try it...... Well, that didn't work, all I got was silence again. does anything go wrong from just sitting for almost 4 years or traveling 1100 miles on a truck? This thing is in brand new condition and was always kept inside. Got any ideas for my next step?
10-21-2012, 03:19 PM #6
Pretty simple machine, Is your power correct?
Odd that your contactor is dropping out, thats why I'm thinking that you don't have a complete 230 Vac to run the unit.
10-21-2012, 09:48 PM #7
- Oct 2007
- Cave Creek Az
- 794
Need to spend a few minutes with multi meter and determine if you have the right power at the outlet first, then hopscotch up the machine a wee bit. I would see if there is another outlet you can try the machine on first.
10-21-2012, 11:00 PM #8
- Oct 2012
- 6
i checked power with multimeter and got 121 volts on each leg at the outlet and also through the welder on / off switch....
10-22-2012, 05:44 AM #9
- May 2009
- Central North Carolina
- 133
You should be checking for 240 volts across the two hot leads, not from each to ground. Check the power at the outlet first, then check inside the welder with it plugged in. With the welder turned on, also check the output side of the power switch. A poor electrical connection can still give you good voltage readings if there is no load, but the voltage will drop significantly after the poor connection when a load is connected.
Charley______________________________
Miller MM252
Miller Bobcat 225NT
2 O/A torch sets
Milwaukee 8" Dry Cut Saw
Milwaukee 9" Grinder
2 Milwaukee 4 1/2" Grinders
Wallace 5 Ton Gantry
Too many hand tools
10-22-2012, 08:58 AM #10
