Page 1 of 3 123 LastLast
Results 1 to 10 of 28
    Sep 2010
    Sorong, Indonesia
    61
    Default Guide me to bumping technique.
    Hi all,
    Tried the bumping tech yesterday, the material is a broken car velg, anodized like a mirror, thickness about 5-6mm. I used Syncrowave 250DX, the settings are: 8LPM 100% Argon, 3/32 1,5% Lant tung, gas lens with cup #6, WP18, 150Amps, balance at 4 (balanced?), wiped with thinner (got no acetone here). I can get a puddle in about 2-3secs, it's a clean puddle.
    The problem is when I dab the filler (4043) for the second time. The puddle will soon contaminated (looks skinny). No problem when first time dab. The cleaning area not seen.
    The question is what did I do wrong? Is it normal not to have a cleaning area when bumping the anodized? Maybe the cup was to small? Amp not hi enough?
    Any information and suggestion is greatly appreciated. Thank you all in advance.
    Jul 2011
    Huntington, NY
    105
    Do search the Weldingweb.com for answers.
    SundownIII is the "bump welding" anodized pro. If you search his posts and the topic itself, you're likely to get some great info.
    Oct 2007
    Cave Creek Az
    794
    Whats a car velg?
    May 2012
    21
    Steph i am running a dynasty 350 i use 5356 rods on boat towers. I also run at about 200 to230 depending on the thickness. Bump get a puddle dab bump dab bump etc. The only differance is i use higher setting and a 5356 rod. Good luck
    May 2012
    21
    Also my cleaning is set to 65 % to let the welder work right. En setting advanced square wave. 75 - 25 EN to EP FREQUENCY of 120
    Sep 2010
    Sorong, Indonesia
    61
    Ok, guys, thank you all for your reply.
    @Walker: Car velg I meant is car wheel. Thought velg is english
    @Drf255: thank you for the info
    @Gaby: unfortunately I still don't have an inverter.
    Still wanna hear from another who bumped the anodized using Sync250DX.
    Thank you.
    Aug 2004
    Milan Michigan
    1,418
    The contamination is probably happening because you are welding a dirty aluminum rim. You have to clean the aluminum.
    Oct 2004
    Edmonton, Alberta
    6,750
    Ahhh, preheat and yes the wheel is likely contaminated, wax or other.
    Sep 2010
    Sorong, Indonesia
    61
    @gaby: you use 200-230amps on what thickness?
    @cruizer: I didnt preheat because I can get a clean puddle in 2-3 seconds. Do I still need a preheat? Maybe I need to change a bigger cup?
    @cruizer & portablewelder: whats your suggestion to clean it? I thought thinner will clean the oil and grease well. I didnt stainless brushed it because it looked very clean.
    Thank you guys for spending time with me.
    Nov 2006
    Lake of the Ozarks MO
    3,446
    Dude.....if you are welding on a car wheel.....you need to give us a LOT more info.
    Keeping the anodize pretty should be the absolute least of your worries.
    This thread is pretty much useless without some sort of decent pics of what you are doing.
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
