Did i read this thread correctly?
Most CK heads interchange with weldcraft?
AND
Weldtec heads inter change with Weldcraft?
I spoke with CK today and the now make an adapter to go between the metric Flexloc head and other heads.
Did I read this thread correctly?
Results 11 to 14 of 14
Thread: I was ALMOST a CK Worldwide fan
03-14-2013, 11:41 AM #11
- Mar 2013
- 21
03-14-2013, 12:18 PM #12
- Aug 2009
- 136
Jbkinn,
I think it is only the FlexLock torch which uses a metric thread on the cable connection rather than the "standard" 3/8" x 24. CK makes an adapter from the 3/8" to the metric so the FlexLock can be attached to a common cable.
Here is what I know about posting a picture: http://www.millerwelds.com/resources...560#post303560
coronan,
I am not sure what you are reading into or out of this thread. As I stated above it is the FlexLock which uses a metric connector, I think most other CK, all Weldcraft, all American Torch Tip and some various generic torches I have use an inch thread - 3/8" for WP9 and WP17 family torches.
If CK has an adapter from the metric CABLE to an inch pattern torch I am definitely interested.
Ken
03-14-2013, 03:09 PM #13
- Mar 2013
- 21
I would like to ultimately have a ball joint head and a flex loc head fit the same handle.
I think it can be done if the weld tec ball joint is generic.
I didnt talk to the Weldtec guy long enough but there is something funny about their "roto head" that is not compatable with with the other weld tec handles.
(metric?)
03-31-2013, 06:14 PM #14
dynasty 200dx and inverter
Possible??
Dynasty powered by an10kw sinewave inverter 12v-240v sources from 2(8D)batteries.....??
What you think?ha
