Results 1 to 3 of 3
    Oct 2012
    Default Dialarc hf ac stopped working
    I have a Dialarc HF serial #JF 860958 from around 1985. I was in the middle of welding some 1/4" aluminum when the arc got unstable so I stopped and re ground the tungsten but when I tried to start welding again there was no High frequency A/C. It produces D/C OK and I can scratch start it but no high frequency for start or continuous use. I checked and reset the spark gaps but that did nothing. Any Suggestions or ideas would much appreciated .
    7,239
    There is either no 120Vac going to the HF transformer, because of a relay, or popped 120Vac breaker or the hF transformer is pooched.
    Oct 2012
    Default Thanks for the tips.
    It turned out that the H.F. transformer was arcing between the windings and its frame. I had to try to initiate the H.F. with the top off of the machine to see the arcing but once I did it was obvious. I replaced it and the machine is working as good as new.
