Results 1 to 6 of 6
    Oct 2012
    2
    Cool Millematic 180 autoset on 110v
    I just moved to Japan and brought my welder with me. I found out that 230v are non-existent in my place (as well as most housing in Japan). So question, can my Miller be run on a 110v? I can't seem to find anything definite on the web on how I could do it.
    Any suggestions would be appreciated.
    -Chris
    Feb 2012
    Wa
    625
    Pretty sure you would need the mm211 with the mvp plug system. Your 180 is a 220 machine only.
    Feb 2011
    20
    Just remember, it's 220, 50 cycle there
    Jun 2012
    Tracy, CA
    221
    Quote Originally Posted by wkdivr View Post
    The frequency of electric current is 50 Hertz in Eastern Japan (including Tokyo, Yokohama, Tohoku, Hokkaido) and 60 Hertz in Western Japan (including Nagoya, Osaka, Kyoto, Hiroshima, Shikoku, Kyushu), however this frequency difference affects only sensitive equipment.
    Taken from:
    http://www.japan-guide.com/e/e2225.html
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    SuitCase® X-TREME™ 12VS
    Multimatic™ 200
    Millermatic® 211 Auto-Set™ w/MVP™ (Sold)
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Victor Oxy/Acetylene Set
    Oct 2012
    2
    Thank you for the comments. I guess I need to study up on some other way to get the power to my welder.
    Oct 2004
    Edmonton, Alberta
    8,110
    Except if your running 50HZ on a 60HZ machine, you'll bake it.
Tags for this Thread
