    Default Generator Question
    I have never welded with my Miller 211 off a generator. Found a deal on one. Was wondering what to look for while test running it before I buy. It has 7,000 running and 12,000 surge watts so it should push the welder just fine. But I know nothing about generators, so if anyone can help me with assurance before I buy it would be greatly appreciated. It's a 6 year old General. He's asking $430. Thanks!
    6,764
    Yep, giver, I see no problems
    Generac I meant.
    Anything to look for during the test run? I just plan on bringing a 4 foot piece of steel and cranking it all the way up, then lay a fat bead that long. That should be all I need to do do to feel comfortable buying??
    6,764
    Actually, what you want to bring is a meter, is case the unit is running way over, or way under voltage and frequency
    You should probably meter the machine BEFORE you plug ANYTHING into it.
    Just a thought.
    Wa
    327
    Why would you need to lay a 4' weld to test it?
    Not sure if that's necessary now, would just a voltage tester in the .240 outlet all I need to check.?
    2,641
    Quote Originally Posted by Packers To Super Bowl !! View Post
    You need to Check the HZ also
    If your meter doesn't do this you can actually do it with a a Kill-a-Watt, about 10 bux at Lowes.
    You'll need 2 lights or something else to to plug in the receptacles to put a load on the generator. Space heaters work.
    Just plug the 2 120v loads in to 2 separate receptacles.
    Jul 2008
    Delhi, Ontario:
    1,950
    Ed,
    What's the purpose of the above test ?
    .........Norm
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - Horizontal Steel Band Saw
    - DeWalt Chop Saw .
