I just moved to Japan and brought my welder with me. I found out that 230v are non-existent in my place (as well as most housing in Japan). So question, can my Miller be run on a 110v? I can't seem to find anything definite on the web on how I could do it.
Any suggestions would be appreciated.
-Chris
Thread: Millematic 180 autoset on 110v
10-15-2012, 07:51 AM #1
- Oct 2012
- 2
10-15-2012, 08:41 AM #2
- Feb 2012
- Wa
- 317
Pretty sure you would need the mm211 with the mvp plug system. Your 180 is a 220 machine only.
10-15-2012, 11:59 AM #3
- Feb 2011
- 20
Just remember, it's 220, 50 cycle there
10-15-2012, 02:23 PM #4
The frequency of electric current is 50 Hertz in Eastern Japan (including Tokyo, Yokohama, Tohoku, Hokkaido) and 60 Hertz in Western Japan (including Nagoya, Osaka, Kyoto, Hiroshima, Shikoku, Kyushu), however this frequency difference affects only sensitive equipment.
Taken from: http://www.japan-guide.com/e/e2225.html
Trailblazer® 302 Air Pak™
Miller Dynasty® 350
Millermatic® 252
Syncrowave 351
SuitCase® X-TREME™ 12VS
Millermatic® 211 Auto-Set™ w/MVP™
Spoolmate™ 100 Series
Diversion™ 180
Spectrum® 625 X-TREME™
10-15-2012, 05:09 PM #5
- Oct 2012
- 2
Thank you for the comments. I guess I need to study up on some other way to get the power to my welder.
10-15-2012, 05:19 PM #6
Except if your running 50HZ on a 60HZ machine, you'll bake it.
