Results 1 to 2 of 2
    Oct 2012
    Default Troubleshooting a miller AEAD 200LE
    I just purchased today a miller AEAD 200le welder. Serial # HE802574. The engine runs fine and the 120v plugs work but it won't hold an arc while welding. I don't know much about the internal workings of the machine so I tried to pull up the manual on here but it brings up a machine with a dial control for amperage and this is one of the old machines where you still have to switch around the cables. Anyone have any ideas what it might be or where to get the proper manual for my machine? Thanks
    Aug 2008
    Orange, TX
    1,058
    You need to enter your SN whem looking up the manual otherwise you get the most current revision.
    http://www.millerwelds.com/om/o411b_mil.pdf
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
