Results 11 to 20 of 32
    Apr 2011
    Raleigh, NC
    10
    Default I'm not complaining
    I was just curious about what would make this $300 - 400.
    Aug 2010
    Los Angeles
    1,170
    Quote Originally Posted by Jbkinn View Post
    So who is quoting you $300 - $400?
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Jan 2007
    Montana, USA
    236
    http://www.shopfloortalk.com/forums/...ad.php?t=23460
    This guy made his own pedal for about $20, and spare parts.
  4. #14
    Apr 2011
    Raleigh, NC
    10
    Default More interest than I thought
    Funny how one thing leads into another. I also came across a homemade HF box. So in both projects the components were not expensive! Thus verifying my original premise.
    I did some checking on commercial prices and found that I was a hundred dollars high.
    The comparison between foot pedal and torch control was something that I was wondering about.
    Thanks again for all your responses.
  5. #15
    Aug 2010
    Los Angeles
    1,170
    Quote Originally Posted by Goodhand View Post
    Although it is always interesting to see people's endeavors, that foot control would last about 2 hours in a production environment. The potentiometer shaft looks unsupported, and the side load will wear it out quickly. As far as resale, forget it.
    But it looks small and lightweight enough to use in other ways. Like an underarm controller.
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
  6. #16
    Aug 2010
    Los Angeles
    1,170
    This rock solid foot control from SSC Controls in the optional chrome finish is $198.
    http://www.ssccontrols.com/TIGchart.htm
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
  7. #17
    Oct 2004
    Edmonton, Alberta
    8,174
    It's alway good to make your own stuff, though that foot control simply won't last long. The idea is to buy something that you know will last like SSC.
    And those parts prices individually cost in excess of $75 not including the ampheol which is another $50
  8. #18
    Jan 2007
    Montana, USA
    236
    Quote Originally Posted by shovelon View Post
    Really? It's amazing how one can think they can diagnose workability from a photo when they don't know how the item works. The pot shaft is very adequately supported, and since the pull on the dacron line from the return spring balances the pull on the line to the pedal, there is essentially zero side loading on the shaft. So, conceivably, failure will occur when the internals of the pot, itself, fails... just as in any electro-mechanical device of like parameters from any supplier.
    I think this pedal was made for use by the designer/fabricator, without any plans to make them for commercial use.
  9. #19
    Aug 2010
    Los Angeles
    1,170
    Really? It's amazing how one can think they can diagnose workability from a photo when they don't know how the item works. The pot shaft is very adequately supported, and since the pull on the dacron line from the return spring balances the pull on the line to the pedal, there is essentially zero side loading on the shaft. So, conceivably, failure will occur when the internals of the pot, itself, fails... just as in any electro-mechanical device of like parameters from any suppler.
    Sorry, did not know it was yours.
    Your pics don't allow me to zoom in on them. Did you put a remote contactor switch in there too?
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
  10. #20
    Nov 2009
    western mass
    208
    after i built my truck, put the crane on it, bolted down the big blue air pak, and all the rest of the junkto go along. then filling the truck and welder with fuel,i couldnt see spending $ 250 on the pedal!
