Results 1 to 10 of 18
    Oct 2012
    6
    Default Service supply lines
    Hello All,
    Just picked up my new welder and was going to start the installation of my electric service for the unit. I thought I could use 8 AWG like most normal 220 circuits, but I'm concerned that it may not meet the needs.
    I will be putting in a dedicated branch circuit and it will be about a 35 foot run. Does anyone have experience setting up service for this welder? Would the 8 AWG get the job done or should I look at 6 AWG or larger?
    Thanks in advance,
    Mac
    8,350
    And your new welder is a what??
    Jul 2011
    NE Ohio
    25
    I am not familiar with the term AVG but I always use 6gauge wire. Seems to keep voltage drop down with and supply voltage more cosistantly. I use THHN.
    Campbell Hausfeld 110V MIG
    Jo Ann Fabrics Hot Glue Gun
    Oct 2012
    6
    My bad, it's the Tunderbolt XL 225/150
    Oct 2012
    6
    Quote Originally Posted by NathanH View Post
    I am not familiar with the term AVG but I always use 6gauge wire. Seems to keep head down with and supply voltage more cosistantly. I use THHN.
    That should have been AWG not AVG. Do you use fuses or a circuit breaker on your disconnect box?
    Jul 2011
    NE Ohio
    25
    I use circuit breakers. You could use a slow blow fuse if that is what you have in your box. You could also get away with 8 gauge wire too. But might as well do 6 as you never know what the future holds for you as far as welders go.
    8,350
    Yep at 35' you'll need #6 to cover your bases.
    2,957
    AWG= American Wire Gauge
    2,957
    Quote Originally Posted by MacDuff View Post
    Hello All,
    Thanks in advance,
    Mac
    Just in case you look at the manual and see odd wire gauge/CB recommendations:
    50amp Circuit Breaker and Minimum #12 wire
    This is due to the Duty Cycle of the machine. NEC allows for using smaller wire on a dedicated run and following the conduit/wire guidelines.
    The Power cord is probably #12.
    Anyhoo- as already mentioned if you use #6 you will definitely be set for any future machines, 100% for any machine that comes from the manufacturer with a 6-50 Plug on the end of the Power cord.
    http://www.millerwelds.com/om/o316t_mil.pdf
    Oct 2012
    6
    Thanks for all the input / responses. The manual is exactly what had me baffled. I may be in for more wiring than I planned as my box in the garage is on a 50 amp breaker and it looks like it was connected with 8 AWG. It's only money and time, right?
