elementary question guys - grounding clamp. I get that it needs to be used, clamped to a ground - so generally the metal table/surface welding piece on. But - can you clamp it TO the object you are working on? For example - if i were modifying a hand truck can I clamp the ground to another area of it...? I guess one welding on a metal table the piece welding on is resting on the table...so...did I just answer my own question? (guess same would go for one welding on an enormous structure or mining truck..clamp to the frame/beams themselves?)
Thx for taking it easy on me.....
outside of this - what would a "no no" be for clamping the ground (outside of to the machine itself)
Results 1 to 8 of 8
Thread: FNEWGUY grounding question
10-11-2012, 07:21 AM #1
- May 2012
- 106
10-11-2012, 08:54 AM #2
- Jul 2010
- 333
10-11-2012, 01:34 PM #3
- Jun 2009
- greenfield new hampshire
- 777
You can ground either way, i have a ground bar welded to my table, but i do not always use it for ground, each job is different, you should always ground closest to the weld if possible, if using the ground bar technique, make sure that the piece being welded makes a clean contact with the steel table, when welding with dc , the ground will on occasion, need to be moved due to arc blow, never, never ground to a shaft in order to weld up its casing,when grounding to the case, arching on the bearings can happen
10-11-2012, 01:38 PM #4
- Jun 2009
- 777
Another nono that i have seen is, which is hard to believe that this has been done is to ground to the ground terminal on the battery while welding on a truck, ect, best thing to do in this case is to disconnect the battery and place the ground clamp close to the weld
10-11-2012, 02:06 PM #5
- Jul 2010
- Four Flags city
- 236
You are creating an electrical circuit......any clean,direct path should be ok.
You would not want to ground something where a bearing surface could be the path of least resistance,for example.
10-11-2012, 02:51 PM #6
Anybody ever see a guy ground to the electrode just to complete the circuit? I haven't but ****....... That would be something.
Trailblazer® 302 Air Pak™
Miller Dynasty® 350
Millermatic® 252
Syncrowave 351
SuitCase® X-TREME™ 12VS
Millermatic® 211 Auto-Set™ w/MVP™
Spoolmate™ 100 Series
Diversion™ 180
Spectrum® 625 X-TREME™
10-12-2012, 05:48 AM #7
- Jul 2010
- 333
10-12-2012, 07:20 PM #8
- Feb 2007
- asheville n.c.
- 595
just make sure your connections are clean, this cannot be stressed enough
