Results 11 to 20 of 20
Thread: Building a motorcycle trailer
10-17-2012, 02:50 PM #11
Trailblazer® 302 Air Pak™
Miller Dynasty® 350
Millermatic® 252
Syncrowave 351
SuitCase® X-TREME™ 12VS
Millermatic® 211 Auto-Set™ w/MVP™
Spoolmate™ 100 Series
Diversion™ 180
Spectrum® 625 X-TREME™
10-17-2012, 03:02 PM #12
- Feb 2009
- Lodi, CA
- 1,126
A flatbed trailer, that might have multiple different loads on it, I prefer dual axles, you have a larger sweet spot to get the center of gravity in.
A single-purpose work trailer, where weight won't vary more than a few pounds fore and aft, is better with a single axle. Easier to hook up and unhook, and move and turn manually if necessary to place it where you want. If you have to pick it up with a forklift, and set it somewhere or hold it 20' above ground, easy to straddle the single axle with the forks, not so much with a dual axle setup.
Unless you are trying to jump corn furrows at 30 mph, I wouldn't worry about the bouncing. My experience is that both portable welders and Harleys are designed to be PORTABLE, you will probably beat your brains out on the truck cab roof before the welder or bike quits.Obviously, I'm just a hack-artist, you shouldn't be listening to anything I say .....
10-17-2012, 03:10 PM #13
I would look around for used trailers first
For either of the 2 trailer projects being talked about in this thread
Kvwall, I would suggest starting a new thread- talking about 2 differently functioning trailers in one thread is gonna get confooosing.Ed Conley
10-17-2012, 03:16 PM #14
10-17-2012, 03:29 PM #15
- Feb 2009
- Lodi, CA
- 1,126
Ed's got a good point here,,,,, it is much easier and cheaper to take an existing trailer, and move the load around, until it's right, and bolt it down.
Just in case anybody's interested, I've been buying all my trailer axles and parts from Southwest Wheel the last few years. http://www.trailerpart.com/
No free shipping, as far as I know, but more important to me is the correct part, in a timely fashion.Obviously, I'm just a hack-artist, you shouldn't be listening to anything I say .....
10-19-2012, 09:31 PM #16
- Jun 2009
- greenfield new hampshire
- 777
yea, ed, i know about the hassle of using ramps, its the same thing with motorcycle jacks, i am looking for some thing used that i can cut, fit then weld together to make what i need, most people around here think that their trailers are made out of gold, the other post have shared some good web sites to check out, thanks for every ones help
10-26-2012, 08:16 AM #17
- Oct 2012
- 1
hey I recently built a three bike trailer for a familly member. If you email me at couparclan@btinternet.com I will send you some pics. Mark
10-26-2012, 02:34 PM #18
- Jul 2012
- 86
Lol
Your supposed to ride motorcycles not haul them.
Miller 211 MVP
Hobart StickMate LX 235
Lincoln AC 225
CutMaster 42
10-27-2012, 08:14 PM #19
- Jun 2009
- 777
Ok, ahh!, let me stop and think about this a bit, the wife just bought a motohome so we can go camping and see the sites, which is great!!!!!!!!, but i would have to leave my 3 harleys home, if only i had a trailer, i could bring the bikes with me
11-02-2012, 07:56 PM #20
- Jul 2012
- 86
I'd rather ride a bike than a wife. Wives always look better in the rear view mirror. :-)
Miller 211 MVP
Lincoln AC 225
CutMaster 42
